fuel relays
Old Jul 6, 2008 | 10:22 AM
liljoe2002's Avatar
liljoe2002
Default fuel relays
can some one tell me where the fuel relays are on a 1993 dodge ram 250 conversion van are located how many and what they look like?tks
Old Jul 6, 2008 | 10:56 AM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Default RE: fuel relays
One relay only for the fuel system.
On my 97 B2500 there is a PDC (Power Distribution Center) on top of the radiator, my relays are in there.
From another thread the relays for a 90 Ram Van are on or in the left fender shield, for what its worth. Try near the battery, on top of the radiator, or see if there is a fender shield that you can remove and find the relays.
On the 97 I can switch several relays with each other for they have the same part numbers. If you try this make sure what relays you swap and that they are the same type.
I hope this helps you.
Old Jul 6, 2008 | 11:54 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
On the 93 there is no PDC, the fuel relay is with the ASD relay on the firewall near the brake booster.
Old Jul 6, 2008 | 01:53 PM
liljoe2002's Avatar
liljoe2002
thanks guys that was a lot of help
