High speed misfire
Also, bad gas with water or other contaminates will cause your problems. How are the fuel injectors and when was the last time you burned high 93 octane 1/4 tank with fuel cleaner?
Why the high octane fuel with the cleaner?
Right now I am trying, and see how it works, the Lucas Fuel Cleaner. So far after about 300 miles on it the engine is running very smooth and even quiter on the highway. Tommorrow I will fill up the van and see what the current MPG is. I bought a gallon of it so that I can try it for the long run. One thing I like is that there is no alcohol in it. It also lubercates the fuel system and top end of the engine.
