98 Ram Van 1500 V6 idling / cut off problem (computer chip)
Old Oct 28, 2006 | 12:24 PM
stev's Avatar
stev
Default RE: 98 Ram Van 1500 V6 idling / cut off problem (computer chip)
Step-by-step, How to clean the IAC ...
https://dodgeforum.com/m_525409/tm.htm
You had mentioned the dealer replacing the idle chip in your first posting. I wonder if they had replaced the IAC. However, that's only 1/2 the fix!!! A new IAC is totally clean, BUT ... the port it plugs into IS NOT, neither is the SLOT under the port hole in the TB casting. Get a few ear swabs, carb/TB cleaner and go to town on this once you review the link.
Your van is a 1998, and if the IAC port and slot have not been cleaned at least once in two years or about 30~40k, then this problem gets worse.
Old Nov 27, 2006 | 04:14 PM
blondieblue227's Avatar
blondieblue227
mentioned to clean the IAC to the dodge service manager during last visit. it seemed the suggestion went right over his head. i'll make sure they clean it this time. their repairs had a one year warranty. it didn't even last two months!
van died again when i was out christmas shopping. it was cold out.
i'm about done with it all, i want a new van for christmas. hehehehe
Old Nov 27, 2006 | 06:05 PM
blondieblue227
Just spoke with the same manager again. He said when he hooked up the computer to check everything the IAC was an option but the computer didn’t recognize that as a problem. Only thing that raised a flag was the crank sensor. And as I said before they already changed that.
Old Nov 28, 2006 | 12:15 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
ORIGINAL: blondieblue227
Only difference this time is I notice after the cut off occurs and I place it in park it rolls by itself a few inches. Like the brakes aren’t working? Also, all my needles moved when it cut off, showing I had no gas, oil etc.
This right here tells you that it an electrical loss of power problem. Could be a bad ignition switch, power relay, battery connection, or a bad connection/connector along your power path. The weak link that's causing the sudden loss of electrical power might also be what's triggering the 500 jump starts counter.
Old Nov 30, 2006 | 05:36 PM
blondieblue227
oh by the way i'm selling a cover for this model van, if anybody's interested. i think it may fit others too. 97, 99, 2000, etc.
click here ----> http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWDVW
Old Jan 4, 2008 | 04:49 PM
blondieblue227
just wanted to say it's happening again.
may i might add that there's a certain sound it makes before it cuts off. more of a wineing tone.
not really looking for answers anymore, just more of a report to help others.
