93 Ram Van: losing vacuum?
Old Mar 22, 2009 | 10:21 AM
fmctm1sw's Avatar
fmctm1sw
Default 93 Ram Van: losing vacuum?
When I'm driving with the blower on, the air flow sometimes redirects down to the floor vents. If I let off the gas, it comes back through the dash vents. I assume this is a sign of a loss of vacuum to the air duct directors (or whatever they're called). Do you think I'm on the right track?
Old Mar 22, 2009 | 12:45 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
You sure it's redirecting to the floor and not the defroster vents? Usually a loss of vacuum directs airflow to the defrosters. Besides a vacuum leak, this can also be caused by the in-line check valve (one-way valve) leaking. This check valve is located in the vacuum hose that leads to the vacuum reservoir for the heating system.
Old Apr 7, 2009 | 09:00 PM
Rusty93RamVan's Avatar
Rusty93RamVan
On my '93 B150 one of my vacuum tubes in the engine compartment near the right firewall (a black one if memory serves) was rubbing against the end of a metal hose clamp near the heater control valve. The rubbing was enough to wear a small slit in the hose where vacuum was being lost. End result was same as you describe, dash vent air being redirected to floor. I replaced the bad tube and everything returned to normal.
Old Jul 25, 2009 | 12:36 PM
gerohan's Avatar
gerohan
how do i check for vacuum leaks? wahaca69@yahoo.com
Old Jul 25, 2009 | 06:04 PM
lilredex's Avatar
lilredex
Under the hood? Take an unlit propane torch and direct it to the suspected area. If idle speed increases sharply........you've found it!
Just be careful.......................
Old Jul 27, 2009 | 09:35 AM
gerohan's Avatar
gerohan
well i give it a try? thank lilredex
