Parking Brake ABS Light
Old Apr 16, 2009 | 12:29 AM
HallofFame2006's Avatar
HallofFame2006
Default Parking Brake ABS Light
Post #1
96; 5.9 auto, AC, 3500, 15 passenger; 68K
Parking Brake & ABS light always was on for a few seconds when starting up.
Had a leak on the lower left corner of the windshield on drivers side; it rained for several days & you could see water running down around the area of the mat at the rear of where the Parking Brake Release Lever is located. Right below the leak of the windshield. Got windshield resealed; now Parking Brake Light/ABS light stays on all the time & brake is not as strong & is lower to the floor.
Looked in my manual; also hooked up to the computer w/my diagnotic tool & no codes. Any ideas?
Old May 8, 2009 | 01:28 AM
khooper's Avatar
khooper
First check the fluid level if ok you need totake it to a dealer to find out what is wrong with the ABS. They set codes in the EBCM just like the engine does in the ecm and can be read with a scanner. Most parts stores con't read these codes.
_______________________________________
Dodge and Lexus Part are now having its sale
