just bought need help b2500
Old May 16, 2009 | 03:08 PM
95blkb2500's Avatar
95blkb2500
By the way thanks for all the help.....Do you know what size bolt is supossed to be with my 3.9 manifold/head
Old May 17, 2009 | 12:32 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
He is talking about a helicoil kit. You can use that if you need (or want) the new manifold bolt to be the same size as the original. With those kits you enlarge the hole and install a threaded insert so that your final hole and threads end up being the original size.
Old May 17, 2009 | 12:35 PM
alloro's Avatar
alloro
Originally Posted by 95blkb2500
Do you know what size bolt is supposed to be with my 3.9 manifold/head
No, but take one of the good ones with you and match it up. I would go with at least a grade 5 bolt.
Old May 18, 2009 | 07:29 AM
95blkb2500's Avatar
95blkb2500
Default bolt canal
Does any one know how long the canal is that the Exaust manaifold bolts thread in to?
