Just dies while driving, then "no bUS" and engine light
Old May 20, 2011 | 09:35 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by markaylasdad
Does this van have a cam sensor?
Yes, inside the distributor, sometimes it's called a pick-up coil.
A NO BUSS message means there's been a loss of communication between the ECM and the dash cluster. For 99.99% of these situations, the problem is either a bad ECM, a bad cluster, or a problem with the wiring between the ECM and the cluster. A bad cluster won't cause stalling. If the ECM has been replaced then you're down to a wiring issue.
Old May 20, 2011 | 03:05 PM
markaylasdad's Avatar
markaylasdad
Default dead ram
Thx for the input. I found a ground strap from the engine to the firewall that was not secure,and had hoped that was it but no cigar! I will take a hemostat and jiggle wires one by one at the plugs. If anyone has any other ideas , please post as soon as possible. I am SERIOUSLY FRUSTRATED.....lol
Old Sep 8, 2020 | 01:25 PM
Trevor Wray's Avatar
Trevor Wray
Originally Posted by BoxcarNY
I have the same problem -- it causes my engine to stall while driving. It happens randomly once the engine reaches peak operating temp. I usually get it going again by pushing down on the third cluster plug on the PCM located (what a great design idea!?!?) right above the hot engine. Sometimes I have to wait till the temp drops a little. I turn the key to RUN position then push down or wiggle the cluster plug until I hear the rely click in the fuse box. Then it usually starts. I cannot seem to figure out if it's a bad connection on the plug (seems like a hundred wires!) or in the receptacle on the PCM. Sometimes it won't happen for a day or two but it always dies when I hit slow traffic. I've cleaned the contacts on both sides with no change.
Another marveous MOPAR design flaw.
I have the treatment but not the cure.
Does anyone have a definative cure for this?
. Did you ever figure out the cure for this? I have the EXACT same problem. When I push down on the last plug, I hear the relay and it starts right up. It's either bad wiring or a bad pcm but I opened up the plug and it looks good and the pcm receptacle also looks good. Stumped.
Old Sep 8, 2020 | 03:35 PM
Probably bad solder joints in the PCM.......
Old Nov 1, 2022 | 06:14 PM
Sam_On_Maui's Avatar
Sam_On_Maui
Hi any solution to the PCM problem? I've had two replacements put in w internal solder joints checked. still randomly dies.
Any suggestions? Did you find a wiring fault?
Thanks
Old Nov 2, 2022 | 03:00 PM
pcdarks's Avatar
pcdarks
I had a mysterious stall problem this summer. Long story short it turned out to be slight corrosion in the connector of the cam timing sensor. I cleaned up the connection and it went away. These vans are getting old enough that a little corrosion will start to show up. I'm going to open all of the connectors to vital components and clean them then apply Dielectric grease to block and future corrosion.
