A/C System fully charged, no cold air. Comp works.
A quick check of the blend door is to have a helper move the slider lever between hot and cold while you watch under the hood at the cable on top of the HVAC box. You should see the cable move and the rod that it is attached to move as well.
98 and newer vans use an electronic blend door. 97 and older use a cable controlled blend door.
Another possible problem may be the expansion valve is clogged, but the high and low pressure readings will help in discerning the problem.
