transmission compatability question
Old Jun 24, 2009 | 05:22 PM
mcdecontrol's Avatar
mcdecontrol
Default transmission compatability question
i have a 1990 dodge ram 350 with the 5.9/360. the transmission is starting to go out. are tranmissions from vans with 5.2's compatable with the larger engine? what other year/years could i look for to get a transmission off of?
sorry for the newbie questions. any help would be greatly appreciated.
thanks!
Old Jun 24, 2009 | 06:31 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The transmissions are compatible but the torque converters are not. The 360 is an externally balanced engine, and being such, there is a counterweight on the torque converter for a 360. The 318 is an internally balanced engine and does not have this counterweight.
Old Jun 24, 2009 | 10:14 PM
mcdecontrol
so if i'm looking for a transmission in a junkyard, i need to pull one from a van with a 360?
is it safe to assume that dodge trucks with a 5.9 would have the same transmission?
also, are other years transmissions compatible?
sorry for all the questions. i'm in a band and our trusty tour van is in need of a transmission. we're pretty attached to this van and we don't want to get rid of it
Old Jun 25, 2009 | 11:30 AM
alloro's Avatar
alloro
Originally Posted by mcdecontrol
so if I'm looking for a transmission in a junkyard, i need to pull one from a van with a 360?
The tranny can be out of just about anything. The torque converter, whether new or used, has to be for a 360 because of the counterweight. Worse case scenario is that you will have to swap your original bell housing over to the new (used) tranny.
Old Jun 25, 2009 | 09:10 PM
mcdecontrol
awesome! thanks for the info!
