cruise intermittent & wheel question
Old Sep 2, 2009 | 01:03 PM
Horton's Avatar
Horton
Default cruise intermittent & wheel question
I tried to search the threads before posting, so plz forgive if this is a repeat question.
1990 Ram Van B250 318/OD. The cruise works fine for about 10 mintues then starts to drop & regain speed, then after about the 5th time of that the cruise shuts off on it's own. Could it be a vacuum leak going to the servo or something else?
Looking for snow wheels, does anyone know which years interchange?
Old Sep 3, 2009 | 04:57 PM
kev2's Avatar
kev2
check the brake switch adjustment also the cruise interupt..being the same as a pick up should be easy to locate wheels.
Old Sep 4, 2009 | 12:31 PM
Horton's Avatar
Horton
Smile
Thank you Kev!
Old Sep 4, 2009 | 07:19 PM
cudajim's Avatar
cudajim
For what it's worth, the cruise control on my Ford Explorer used to be intermittent. It would work for a while then turn itself off. Some days it would work for as much as an hour or two. I finally fixed it after 3 years. I pulled it apart to get to the electronic board and one wire was wrapped to the terminal but not soldered. All other wires were soldered. Anyhow, I soldered it and it's worked great ever since.
Old Sep 8, 2009 | 04:34 PM
Horton's Avatar
Horton
Smile
Thank you. I may dig into the steering column and follow the yellow brick road from there!
Old Sep 9, 2009 | 06:46 AM
kev2's Avatar
kev2
start at brake switch- cruise control interupt - more than one switch on brake
if you have a trailer harness ck
under hood -vacuum lines
