new to forum have questions need help
Old Sep 19, 2009 | 01:07 AM
22dodge's Avatar
22dodge
so then apply your vast knowledge of how to fix his problem instead of being bitchy!!
Old Sep 19, 2009 | 12:11 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
I already suggested a course of action in post #3. I'm waiting for him to do it and see if the problem is cleared up.
Old Sep 19, 2009 | 09:30 PM
refertech's Avatar
refertech
hi and thanks I sleaned the iac today looked pretty similar to the pics it needed it . when I started it after it hissed as if the I ac was adjusting itself and smoothed out pretty well still has a little lope under load in gear at stop nothing like it did . thanks
Old Sep 19, 2009 | 09:51 PM
alloro's Avatar
alloro
Sometimes disconnecting the battery for 10 minutes or so then reconnecting it will get rid of that loping. The reason being...over time the computer learns how to control the engine more efficiently than by using the preprogrammed defaults. Now that you've made this repair the engine is responding differently...those same learned parameters no long apply. Disconnecting the battery clears out the learned programming and starts you off from scratch.
