RamVanSensorsGoneWild
Old Sep 24, 2009 | 02:21 PM
RealDealSER's Avatar
RealDealSER
Default RamVanSensorsGoneWild
how ya doin guys,im not the owner of this 2000 dodgeramvan 1500 V6 its my brother in laws but he isnt computer savy.heres whats goin on.ABS,brake and engine lights are on.he changed the brakes all around to super heavy duty break pads/shoes and oem front rotors.if anyone can help or has had the same problems please help.he is going to autozone to see what codes its throwing and i will update this.thanks
Old Sep 24, 2009 | 03:45 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
4-Wheel ABS or just Rear Wheel (RWAL) ABS?
4-Wheel ABS has sensors on both front wheels and the RWAL ABS does not.
Old Sep 24, 2009 | 08:25 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
The only time that I have seen this personally is when a VSS sensor had gone bad. But not only were the lights you said on but the OD Off light was on and the speedometer did not work. Is the speedometer and odometer working? If they are then the VSS should not be the cause.
Old Sep 29, 2009 | 12:53 PM
RealDealSER
i think it has ONLY front wheel ABS and no the speed/odemeter both are NOT working.thanks guys,i will pass this info on.
Old Sep 29, 2009 | 02:30 PM
alloro's Avatar
alloro
the speed/odometer both are NOT working.
Well then like "Mobile Auto Repair" said, replace the VSS or at least inspect the wiring to it for damage.
