Leans to one side
Old Mar 31, 2010 | 06:53 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by benwillcox
My spring wire diameter is 22mm, which equates to 7/8", or 0.875", so I would have thought it is the Moog part# 7272 on that page.
Does this sound correct, or is there something else that I need to take into account here?
My advice in situations like this is to tell people to contact the seller. They might be able to tell you the reason for the different spring specs. But more importantly, if you buy based on their supplied information, you will have a much easier time exchanging them if something ends up not being correct.
Old Apr 1, 2010 | 04:05 AM
benwillcox's Avatar
benwillcox
Thanks Alloro, I have indeed asked them for their advise, and it was then that they came back to me and said that I shouldn't rely on the original wire size being equivalent to the replacement parts, as manufacturing differences might mean different wire sizes give an equivalent ride, but with no suggestion as to which of the 3 type is correct!
I have responded back to them with the part numbers from the existing springs, and hopefully they will be able to advise the correct replacements. Incidentally, if anyone here has access to a part number cross reference, here are the codes on the labels on my springs, googling has given me no answers:
Spring 1:
215
71765
52039215
Spring 2:
214
71765
52039214
I also found a thread here: http://www.*********.com/forums/showthread.php?t=252371 which refers to the 3 different wire sizes of spring, but they are talking about B150 vans, which I guess perhaps use a lighter duty spring than my B2500 (heavy) conversion van.
Edit: For some reason that url is censored, but it is 'the other' dodge place where people like to 'talk' about them.
Thanks,
Ben
Old Apr 1, 2010 | 07:29 PM
benwillcox's Avatar
benwillcox
Arghh!!
Rock Auto have replied with :
We cannot cross reference to the Chrysler part number. However, to order the Moog part, please order according to the year, make, and model, and engine displacement of the vehicle, and then according to the specific specifications listed in the part description. We do list Moog springs for the van, and there are details in the part description concerning such matters as GVW rating, etc.
So I'm not getting much help from them! Their site lists 3 possible springs for a B2500 van. I am just hoping some one on here knows which is the correct spring for my van! I don't really understand why they can't suggest a suitable replacement for my existing chrysler part number, I think I will have to just get the heavy duty version which matches my spring wire diameter of 7/8" unless anyone here knows any different?!!
Thanks,
Ben
Old Apr 2, 2010 | 02:05 PM
benwillcox's Avatar
benwillcox
I was reading some threads on the 2nd gen Ram truck forum where people have requested build sheets for their Rams from Chrysler. So I sent off an email in the hope it would help me identify the springs I need.
To my surprise I got a reply within about 1/2 hour with the info, that's top service! I'll paste it here just for fun:
Sales Code Description
*ZZ Temporary Driver Seat
ADCP Convenience Group
ADPP Heavy Duty Suspension Group
AEAP Exterior Appearance Group
AEBP Street Appearance Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
BANP 120 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGKP 4-Wheel Anti-Lock Brakes
BKGS 11x2.5 Rear Drum Brakes
CDSP Swivel Driver Seat
CGTS Driver Air Bag Only
CHSP Vinyl Sun Visors
CJAS C/Coded Front Compartment Trim
CJBP C/Coded Front Compartment Trim
CJEP Side & Rear Doors Trim
CK8P Delete Front Floor Mat/Carpet
CLPP Door Sill Scuff Pads
CTAP Front Lower Door Trim Panel
CYBS Bucket Seats
CYXS Delete Rear Seating
DGB All 4-Speed Automatic Transmissions
DGRS 4-Spd. Automatic 46RH Transmission
DHAS Lock-Up Torque Converter
DJBS 5,500# Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAAC All Engines
ELF 5.2L V8 MPI Engine
GACP Tinted Glass Windows
GAHP Vented Glass
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GGAP Panel Van Glass
GHDP RR & RT Side Doors w/Glass
GJCP Right Hinged Doors w/Vented Glass
GJFS RT Hinged Doors
GLCP Rear Hinged Doors w/Vented Glass
GLFS Rear Hinged Doors
GNAS Rear View Day/Night Mirror
GPSP Power 6 x 9 Black Mirrors
GVBC All Vehicles W/Power Mirrors
GXRP Keyless Entry
HAAP Air Conditioning
JBAP Instrument Panel Lower Skirts
JBBP Instrument Panel Woodgrain Bezel
JCDS 100 MPH Primary Speedometer
JFBS Oil Pressure Gauge
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JKAS Locking Glove Box
JPAP Power Windows
JPBP Power Locks
LAAP Ignition Time Delay Lamp
LACP Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LALS Low Washer Fluid Warning Signal
LBCP Glove Box Lamp
LBEP Cigar Lighter
LDAP Underhood Lamp
LMAS Halogen Headlamps
MFEP Bright Grille
MKDP Bright Bumpers
MKEP Bright Rear Bumper w/Step Pad
MKFP Bright Front Bumper
NAAS Federal Emissions
NBHA High Altitude Emissions Tracking
NBKS EVAP Control System
NFFP 35 Gallon Fuel Tank
NHMP Speed Control
PX9 Black
QX9S Black
RAAC All Radio Equipped Vehicles
RASP AM/FM Cassette Radio
RCEP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCHS Sport Steering Wheel
SFBP Front Heavy Duty Shock Absorbers
SGBP Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBP Full Size Spare Tire
TBHA Inside Floor Mounted Spare Tire
TSDP P235/75R15 WSW All Season Tires
TZHP Michelin Brand Tires
WJMP 15X7.0 Chrome Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
XEHS Jack w/Wrench
YAAS Build To U.S. Mkt. Specifications
YFAA Incomplete Type VIN Indicator
YGKA 15 Additional Gallons of Gas
ZDRP Spring - Left Rear
ZHJP Spring - Left Front
ZSRP Spring - Right Rear
ZWKP Spring - Right Front
1ARS U.S. Recreational Vehicle
169S Zone 69-Phoenix
2TFA Customer Preferred Package 2TF
26F Customer Preferred Package 26F
3VSA Customer Preferred Discount
So, it appears that heavy duty suspension and shocks are specified, which confirms what I thought based on the spring wire diameter, the part description in RockAuto's listings, and the GVWR label that states 6800lbs. So, Moog 7272 it is then!
Ben
Old Apr 2, 2010 | 11:40 PM
alloro's Avatar
alloro
Knowledge is power!
Old Feb 20, 2013 | 10:05 AM
Kuntzee's Avatar
Kuntzee
check your running boards i had the same issue the right one is mounted slightly lower then the left due to the side doors ..... mine is almost a inch , i fought this issue for some time when trying to level my van when pulling my travel traile and inflating my air bags .......
