it goes on then it turns off
Old Feb 3, 2010 | 06:05 PM
zanko79's Avatar
zanko79
Default it goes on then it turns off
Well today i had this wierd problem, first of all I have 1997 dodge van B2500. I tryed to start a van today and it comes on but it turns off immidietly, anyone has any clue what could be a problem i had similar problem couple weeks ago
Old Feb 3, 2010 | 06:58 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Blown fuses under the hood perhaps. If not, the ignition switch acting up would be next on the list.
Old Feb 5, 2010 | 11:12 PM
RussellRowell's Avatar
RussellRowell
Loose or damaged wire harness connections at distributor, coil, or alternator. Check the ignition ballast resistor. Check all intake manifold vacuum hoses. Last, check for insufficient fuel flow. GL
