Need fues sizes
Old Feb 22, 2010 | 09:03 PM
73dart's Avatar
73dart
Default Need fues sizes
I am putting a 318 from a 90 B250 in my Jeep. I need to know what the fuse size for the main 12 harness, and fuel pump.
Old Feb 22, 2010 | 09:09 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Since your question has to do with the Jeep chassis, you'd be better off asking in a Jeep forum.
Old Feb 23, 2010 | 08:53 AM
73dart's Avatar
73dart
The motor came from a 90 B250 van. I need to know the fuse sizes that were in the van so when I wire it into my Jeep I can properly protect it.
Old Feb 23, 2010 | 05:53 PM
alloro's Avatar
alloro
I'm not sure what you're trying to find fuse sizes for. There are no fuses for the motor. Is there a specific circuit you're asking about?
Old Feb 23, 2010 | 07:47 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
If your wiring harness includes the fuse links from behind the vans brake booster then you need the while fuse link that is attached to one of the orange links. This white one will go to the ASD relay and the SBEC (engine computer) pin 3. The ASD relay will power the engine and fuel pump.
Old Feb 23, 2010 | 08:18 PM
alloro's Avatar
alloro
All of which are chassis components. I'm not following him as to why there needs to be different fuse ratings simply because of an engine swap???????
Old Feb 23, 2010 | 09:27 PM
Mobile Auto Repair
His signature says: 1989 Jeep Wrangler, 2" lift, 8000 lb winch, gathering parts for a TBI 318 swap.
I believe he is going from carburetor to TBI.
Old Feb 23, 2010 | 10:34 PM
alloro's Avatar
alloro
His signature says:
Hmm, okay...it would've been a bit less confusing to just say so in the first place. I generally don't read people's signatures because 99% of them contain things only important to that person.
Old Feb 24, 2010 | 06:58 AM
73dart's Avatar
73dart
Mobile, that was excatly what I was looking for thank you. I have one more question. According to my wiring diagram, there is a DKBL wire that comes form the ignigition switch that is hot in the start and run position. It goes through the ASD to feed the +12v to the coil, injectors, engine sensors, and CEL. Can you tell me which fusalbe link it is or what size fuse it requires?
Old Feb 24, 2010 | 07:50 AM
Mobile Auto Repair
That wire is already fused before the ignition switch, you will not need to add another fuse to it. That wire will trip (turn on) the ASD relay circuit.
