77 b200 problems
Old Feb 25, 2010 | 07:45 PM
bjl8691's Avatar
bjl8691
Default 77 b200 problems
van starts and idles normal when you put it in gear and hit the gas it kills you can put it gear and hold the brakes it wont kill unless you release the brakes and hit the gas any ideas as to what the problem is has rebuilt carb new fuel filter and pcv valve
360 carter 2 bbl
3 speed automatic
Old Feb 25, 2010 | 11:06 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Can you ease on the gas to get it to go? Are all the vacuum lines connected and working? It may be the accelerator pump not working even though the carb is rebuilt. Do this with the engine off. A test to try is take off the air cleaner top. Look down into the carb, hold the choke open and move the throttle while looking for a fuel spray. If no fuel spray then pull the top of the carb off and repair/replace the accelerator pump.
Old Feb 25, 2010 | 11:35 PM
bjl8691's Avatar
bjl8691
all vacuums are connected i will check the acc pump yes you can ease on the gas and it will go but if you hit the gas like you normally would it will kill if you double foot it brake and gas at once you can drive it
Old Feb 25, 2010 | 11:54 PM
Mobile Auto Repair
Also check the brake booster for a vacuum leak. It is either the accelerator pump or a leaking brake booster.
Old Feb 26, 2010 | 01:19 AM
bjl8691's Avatar
bjl8691
brake booster interesting i just did new calipers wheel cylinders lines and master brake light is still on maybe there is a vac leak at the booster
Old Feb 26, 2010 | 10:48 AM
Mobile Auto Repair
On the master brake light check that the e/parking brake pedal is pulled all the way up. I have seen a few that by pulling the release handle and pulling up on the pedal that the lamp would go off.
Old Feb 26, 2010 | 04:07 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
That's true, but considering that the brake lines were just opened up, I'd lay odds that the system is still air bound and the proportioning valve sensor is what has the brake light turned on.
Old Feb 26, 2010 | 11:18 PM
bjl8691's Avatar
bjl8691
i pulled the carb apart everything is A-1 i noticed on the brake booster the check valve grommet is cracked i will replace it and keep you posted
thanks eveyone for the help sometimes you get odd problems that keep your mind spinning
