dashboard vents
Old May 23, 2010 | 02:10 PM
wilbo's Avatar
wilbo
Default dashboard vents
Guys
I can't seem to get any air through the dash vents. The blower is working and blows through the floor and windscreen (defrosher) vents. No matter what setting I have the vent lever (normal or bi-level, or any other), it never blows through the dash vents. I assume this is a mechanical control (what switches the air flow from floor/dash/defrosh vents)?
Any ideas what this might be??
thanks
Wilbo
Old May 23, 2010 | 07:32 PM
cgees1500's Avatar
cgees1500
I had a similar problem with my 96 dodge van found vaccum lines under hood to be dry rotted.
Old May 24, 2010 | 01:55 AM
wilbo's Avatar
wilbo
ah, that could make sense. I've been doing a lot of work in and around hood/firewall recently. Is there a specific hose/line I should look for? Should I look under hood or inside cab? I suspect I've dislodged something
Not sure if this is related but recently I've noticed the idle isn't steady and I know this can be related to vacuum??
many thanks
Wilbo
Old May 24, 2010 | 11:20 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
On the passenger side of the intake is where the HVAC vacuum line connects, along with it's one-way check valve. From there it runs to the vacuum reservoir behind the passenger headlight. Then from there it runs through the firewall to the dash controls.
Old May 25, 2010 | 02:15 AM
wilbo's Avatar
wilbo
thanks, found that one. So best way is to remove the lines and check for leaks/breaks? There is certainly a good 'pull' coming from the HVAC line engine point. I'm hoping a line has become disconnected rather than leaking. The check valve can give up as well ? Do you think it could be a flap problem where the air is mixed?
Wilbo
Old May 25, 2010 | 11:03 AM
alloro's Avatar
alloro
If you mean the hot/cold air mix (blend door) then no. It could however be the vacuum actuator that switches the airflow from floor to vent to defrost.
Did you try applying vacuum to the HVAC vacuum line from the side of the intake to see if it holds vacuum?
Old May 25, 2010 | 11:33 AM
wilbo's Avatar
wilbo
Yeah I mean the floor/vent/defrost flow. As I cycle through the buttons (normal/bi-level/heat/defrost) there is a change from defrost to floor as in the defrost setting has more flow to floor than when on the heat setting - not much but I can notice a difference. So 'something' is moving a bit.
All I've done so far is pull the line from the intake and stick my finger on the intake line which is sucking like crazy. I've visually checked the lines but not back to vacuum reservoir or from there back to dash. I'll check those lines next.
I've read about trying to notice a hissing when diagnosing these problems, which I think I can hear above the noise of the engine. I think I might have dislodged something when doing the plugs and wires...?
Do you mean testing the reservoir end of the line with the other plugged in normally?
many thanks!
Old May 25, 2010 | 05:55 PM
wilbo's Avatar
wilbo
Found it!
Looks like the thin black line from the T back into the dash got melted on something (probably close proximity to heater core lines).
My neighbour had some identical black vacuum line from his bike - product called Scottoiler if anyone can't any original.
thanks Alloro and Cgees
Wilbo
Old Sep 28, 2010 | 02:37 PM
kenny63's Avatar
kenny63
Default help no airflow in defrost or floor vents
Guys
thanks
kenny lester
Wilbo
help no airflow
Old Sep 28, 2010 | 04:22 PM
alloro's Avatar
alloro
Originally Posted by kenny63
help no airflow
We're not mind readers, try explaining the problem better, what causes it, any steps you've taken to try and narrow down any of the components which could be bad. I could simply reply, "open your window" to what you've written.
