Help '87 B250 Vapor Lock
Old Jul 8, 2010 | 02:41 PM
Larceny's Avatar
Larceny
Default Help '87 B250 Vapor Lock
Hi all i'm new. I have a '87 B250 318 with a mech fuelpump and i am haveing BIGTIME vapor lock probs. what is the fastest and cheapest way to fix.
Old Jul 8, 2010 | 03:20 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Move the fuel lines away from any heat sources such as heater/radiator hoses, exhaust manifolds, the engine block, etc. If that fails to solve it, then a thick gasket under the carb to help insulate the carb from engine heat will do the trick.
