Flashing oil warning light
Old Aug 31, 2010 | 10:37 AM
akwi's Avatar
akwi
Default Flashing oil warning light
Hi, I have an B250 Royal van 1987 and suddenly the oil warning light started flashing, but the meter to the right is showing an ok value.
I looked at the motor oil dipstick and saw that the oil level was to low so I gave the engine about litre. Now the oil level is between add and full but the warning light is still flashing. Why ?
Does anyone have an explanation ?
Martin from Sweden.
Old Aug 31, 2010 | 10:49 AM
dakota_raven's Avatar
dakota_raven
oil change due, maybe?
Old Aug 31, 2010 | 11:19 PM
landyacht318's Avatar
landyacht318
The gauge and idiot light are not to be trusted. You can buy a mechanical gauge for about 30$(here in the US anyway) that gives you real time oil PSI, instead of the 30 to 45 second delay with the Stock electric models, or you can hook up a tester and see what your PSI really is with a hot engine at idle speeds. You can also just buy a new sending unit for 3 to 33 dollars.
Are you getting any engine noises when the light illuminates?
This is a photo of what RockAuto says an oil pressure switch looks like on an '87. It looks different on my '89 which has a taller electrical connector. It is about 6 inches to the right of the distributor. Check the wiring.
Old Sep 1, 2010 | 02:46 AM
akwi's Avatar
akwi
Thanks for your quick answers.
I hear no noise when the light flashes and.
Why is there both a light and a meter, the light to the left and the meter to the right.
The meter rises nice up against the H (high), I suppose that means high (normal) oil pressure.
The oil is black so I must change it anyway, at the same time I will buy a new sending unit and then I will see what happens.
Thanks again
Old Sep 2, 2010 | 10:41 AM
akwi's Avatar
akwi
Angry still flashing
Hi, I have changed oil and filter in the engine now, but the warning light still flashes.
Must be some electric problem.
Martin
Old Sep 2, 2010 | 06:48 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Turn the key to on position, But DO NOT start engine. Then push the gas pedal to the floor 3 times within 5 seconds, then turn key off.
For many vehicles this is the standard oil light (or service light) reset procedure after doing an oil change. See if that solves the problem.
