Vehicle speed sensor.
Old Sep 11, 2010 | 10:52 PM
Captain Wally's Avatar
Captain Wally
Default Vehicle speed sensor.
I have a 1998 Ram Van 1500 with V6.
I have "ABS" and "BRAKE" lights lit and speedo doesn't work.
I get error "P0500 MOD $D1 1/1 Vehicle Speed Sensor Malfunction".
I assume this sensor is located on top of the differential.
I bought a replacement sensor at NAPA, and it looks like the connector is located at the top of the unit, aiming up.
I looked at mine, and the connector is at a right angle, under the shield.
Do I have the wrong replacement part?
Am I looking at the wrong sensor?
I hate to beat a dead horse, as I'm sure this was covered in these forums somewhere, but I can't seem to find it.
Help!
Old Sep 12, 2010 | 02:48 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Take a look at the back half of your tranny and see if there is a sensor there that matches the one in your hand.
Old Sep 12, 2010 | 11:47 AM
Captain Wally
Thanks.
Will do.
Old Sep 15, 2010 | 05:55 PM
Captain Wally
Thanks Rich. I went looking at the trans. No dice.
Alldata showed the sensor on the rear axle, above the differential.
After much searching around, I found the proper replacement.
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
http://www.autozone.com/autozone/par...artNumber=true
Autozone calls it a Duralast / Brake Sensor. Part# SU8172.
I bought mine at NAPA part# 530778.
They call it an "ABS Differential Speed Sensor".
I installed it and the "ABS and BRAKE" lights went out, as well as the "Check Engine" light.
The speedo works again.
I hope this helps.
