Tranny slip, dying, and PCM HELP!
Old Sep 23, 2010 | 10:29 PM
straddlecreek's Avatar
straddlecreek
Default Tranny slip, dying, and PCM HELP!
Hello from a noobie,
My wife and I recently bought a 2000 Ram Van 3500B with 98,000 miles from a private party. It ran fine at first, but now sometimes, not always, the transmission hesitates/slips at about 25-35 mph.
The other day, I had trouble starting the engine. It took several tries, but I got it to run. I got about 5 miles from home (going about 30 mph) when it suddenly lost power, then started to run herky jerky, then died.
The Dodge mechanic has not been able to duplicate the problems.
Diagnostics return no fault codes, however the PCM returns no response. The five-fold signal checks okay and power/ground to PCM checks okay.
They want to replace the PCM for $1,000.
I'd like to buy a refurbished PCM and either do it myself or have a different mechanic help me with it. The dealer mechanic says the PCM has to be reprogrammed with his diagnostic computer, so we have to have them do the work. Is this accurate?
Could the tranny problem and dying be related? Is the TCM a part of the PCM in our model van?
Also, I've found online info that says the PCM is under the hood. And another that indicates it might be under the driver's seat. There is a black box under the seat in our van with what looks like heavy duty power cords going towards the engine. Is this the PCM?
Thank you for any and all help with this!
Old Sep 23, 2010 | 11:24 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Your PCM has a set of numbers on or in it, these must be match up exactly when replacing. No you do not need to have it reprogrammed by the Chrysler dealer. The PCM is located under the hood in the center of the firewall above the engine.
The TCM is separate for you year van.
Yes the transmission problem may be PCM related for the PCM and TCM "talk" with each other as you drive.
The black box under the drivers seat is for the air bag system.
Old Sep 24, 2010 | 02:21 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
I don't supposed they tested for fuel pressure? Those symptom sound like a fuel pump problem to me. You should have 31-33 PSI at idle.
Old Sep 24, 2010 | 11:35 AM
Chazwel's Avatar
Chazwel
I agree on the fuel pump. I replaced mine in a 2000 Grand Caravan. It is located in the fuel tank. I changed the fuel filter also, it is located in the fuel tank too. When the fuel pump was starting to go out, the engine started to stall but would start back up (it was giving me a sign), then about 2 weeks later ( I didn't know what the problem was) bam she was dead
