Malfunction Indicator Light after replacing PCM?!
Old Oct 13, 2010 | 11:59 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Sounds like you're losing (or lost) the ground bonding from the engine to the body.
Old Oct 13, 2010 | 12:47 PM
straddlecreek's Avatar
straddlecreek
OK, I just checked all the grounding wires from the battery, making sure all was well connected. It all seemed good. I then started the van. Sounded good. Did key on/off and all three codes are coming up again!Aaargh!!
One other thing I've now noticed: The negative wire to battery is as tight as I can get it, but I can easily pull it completely off of the negative terminal. Could that be the problem with the 'switched battery'?
Old Oct 13, 2010 | 12:56 PM
landyacht318's Avatar
landyacht318
That could be all your issues. Eliminate it as a possibility.
Replace the battery cable, or jam a screw or two between connector and stud.
Weak intermittent grounds are the source of 85% of electrical issues.
Old Oct 13, 2010 | 09:08 PM
stev's Avatar
stev
There are other grounds for the vehicle. Check the ground straps from the engine and tranny to the body vehicle frame.
