96_2500 Conv Van 5.9L
Old Oct 17, 2010 | 08:12 PM
Riles's Avatar
Riles
Default 96_2500 Conv Van 5.9L
I am having problems with my '96 2500 van (5.9L) w/4 spd auto. Starts good, accels good, but at cruising speed, (no load) it shakes & misses like crazy. Give it gas and it accels great. Does it in either 3 or 4th gear. I have replaced plugs, cap & rotor, pickup coil, & air filter. Same problem. It did run fairly good last evening at 70 MPH but detected a surging at interstate crusing speed. (w/cruise on)(Gas tank read about 1/4 full.) Any ideas?
Old Oct 17, 2010 | 09:02 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
I'm going to say your fuel pressure is too high. This could be due to a bad pressure regulator or the vacuum hose going to it is leaking.
Old Oct 17, 2010 | 09:04 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
What is the trans fluid level? When was it last changed and the bands tightened?
Also does it do it with the fuel tank full?
Old Oct 17, 2010 | 09:05 PM
Mobile Auto Repair
Alloro the fuel pressure regulator on this van is also in the fuel pump module in the tank, not on the engine.
