Reprograming ECU
Actually, for your generation of Ram Van, it's called a PCM.
There isn't much to really reprogram the PCM with. Chrysler has a few TSB required reprogramming needs if the van doesn't pass emissions or if the engine has a diesel ping for your model year. They have to mount a sticker to your van computer that says the PCM has been reprogrammed by the dealer to avoid any Federal legal action.
If you have the B2500, then the rear 3.92 would do well for towing.
As for upping or returning lost power, there are a few things to do.
1. Use the Autolite AP5224 Single Platinum plugs.
2. Cap-n-Rotor must be copper/brass contacts.
3. Replace the O2 sensors and the CAT if the mileage is around 90-100K.
4. Have a high flow CAT and high flow muffler. Done this in the last two months to my 2001 5.2L. This made an enormous increase in power. The exhaust pipe diameter is 2-1/2. Also, the Y-pipe connection going into the CAT is by far better than OEM setup of having the pipes get pinched together before entering the CAT.
5. There is an IAT mod that 97B2500CCV has done. This is the first of it's kind that can be switched on/off on demand vs. the IAT mods for the Magnum engines shown on the web. His method is the best thus far. This isn't "reprogramming" the PCM, but it fakes the PCM out allowing for more Hp out of the engine. Of course, this uses more fuel too. So, having the option of "on demand" when needed helps with this mod.
6. Make sure your van has an OEM or additional tranny cooler. A hot tranny can reduce the power to the wheels.
7. Run with the 75W90 synthetic rear oil in the differential. Chrysler has a TSB recommending this.
8. Repack the front wheel bearings, both the inner and outer on each side. Friction is your worse enemy for fuel MPG and for towing. I'm using a high viscosity bearing grease from a Tractor Supply Store that is sky blue in color, a premium corrosion inhibitor and will not wax up under heat.
9. To greatly reduce the sag and add rear control for towing, get the Road Master Active Suspension Kit added. This will put the weight of the trailer where it out to be, on the trailer and not adding the force/pressure on the rear springs of the van.
10. Clean the engine breather, the PVC valve, the IAC, and seafoam the fuel intake.
