'99 Dodge Ram Van
I have a question...went out to start my van and when i turn the key there is NOTHING. Just the buzzing from the key being in the ignition. Even tho the battery was replaced last December I hooked it up to a charger, no luck...I've read a lot about an ASD Relay? Could this be the problem, and if so, where will i find it and how will i know if it's bad? Thanks!!
Ok, so I can scratch that....so what where should I start? I've just replaced the water pump, outgoing speed sensor, thermostat...in the past month or so....not related, I'm sure, but now this....I have no clue what it could be. It's almost like the battery is dead, but not the case!? The battery tested good when I hooked it up the the charger...any suggestions? PLEASE?! On thanksgiving day it was cranking, but almost sounded like it wasn't getting fuel. Then when gas pedal was pushed it would die. Finally got it started and it's started fine ever since....until Sat night....went to start it, turned the key and NOTHING! I don't even know where to begin!!
It could be, it's mounted on the starter. I'd still first test the neutral safety switch. Unplug the 3-wire connector from it and ground the center wire (only the center wire.) Then try to start it. If it starts replace the switch. If it doesn't start then replace the starter assembly.
Trending Topics
Before replacing the starter check the small wire on the starter for power when the key is turned to the start position. If power then replace starter, if no power and not the neutral safety switch then look at the starter relay.
We're a bunch of men that know a lot about car and almost nothing about women, and we refuse to learn.
Thanks again for the suggestions!
