Need Overdrive on transmission what will work
Old Mar 26, 2011 | 11:32 PM
vanwildman's Avatar
vanwildman
Default Need Overdrive on transmission what will work
Just wondering if there is a transmission for my van that has overdrive. It's a 1986 B350 Maxi 5.9L with a 3spd. Is there something that would bolt on to existing transmission.
Old Mar 26, 2011 | 11:37 PM
landyacht318's Avatar
landyacht318
http://www.gearvendors.com/ag3s.html
Old Mar 27, 2011 | 01:48 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
If you can find a 518 tranny from a junkyard, you can do a conversion.
http://www.transmissioncenter.net/SwapInformation.htm
Old Apr 7, 2012 | 03:13 PM
72dodgevanman's Avatar
72dodgevanman
Default Conversion from 727 to 518 Transmission
The 518 Transmission was the answer for me in getting to an overdrive. I have a 4:10 Differential and run about 2300 at 70mph in overdrive. I researched everything and finally settled on the 518. I control the Lockup, Overdrive, and Downshift with pressure and vacuum switches as my 72 was before electronics. I have two pressure switches which control the torque converter unlock and lockup and the control of the overdrive function. The vacuum switch is used for downshift out of overdrive. I also have installed dash switches to manually control the overdrive and lockup. It works great without the electronics. I have also recently upgraded my old 360 to an 408 which I bought from Blue Print Engines. The 408 is now back at Blue Print with a knock. Will know next week whether they stand by their warranty.
