1996 b2500
Old Mar 30, 2011 | 02:27 PM
mark weinberg's Avatar
mark weinberg
Default 1996 b2500
my van has been giving me problems strating in the mornings it will not start right up takes a few key turns to get it started then some times will start and run rough die takes some times 15 min to get running right and then runs fine but never know if it will start up right next time i get in it what is wrong with my van
Old Mar 30, 2011 | 06:26 PM
landyacht318's Avatar
landyacht318
Could be a faulty check valve in the fuel pump assembly.
Try turning the key on(not start) and off several times before cranking the engine in the morning.
If it fires right up, the ultimate solution is a new fuel pump assembly(inside the gas tank), but you can add a check valve on the line outside the tank.
http://www.restockit.com/fuel-line-c...rrckv5%29.html
