How does a bent push rod...
Old Apr 12, 2011 | 10:52 PM
battleaxe's Avatar
battleaxe
Question How does a bent push rod...
make your engine run?
Tried everything to solve what feels like a constant miss. Almost everything except replacing fuel injectors. Loss of power @ 50%. Problem used to be intermittent.
Computer reads good... I have replaced every dang thing that bolts up to the motor near about.
Was thinking injector or bent push rod... now.
'93 5.2L B250
Old Apr 13, 2011 | 02:47 PM
landyacht318's Avatar
landyacht318
When my buddy had a cam lobe go round on his Small Block Chevy, it seemed as if the engine was missing. I assume a bent pushrod would have a similar effect, but am mostly posting this to bump it up for you.
It would not bee to difficult to check for a bent pushrod, and with a roller cam, you probably can rule out a flattened cam lobe.
Old Apr 13, 2011 | 07:03 PM
Bad Van Momma's Avatar
Bad Van Momma
Same thing was happening with my van. Check the coil, cap/rotor (I changed them out and a world of difference)
And the transmission....These 93 big baby's have notorious transmissions (especially the 4 speeds).
Even with a bad tranny (brass ring in front pump chewed up and scratched torque converter at the very least) I never got a check engine light or a bad code.
I truly hope it's not your tranny or that you have a 3 speed. The 4 speeds are impossible to find if you have a small budget. The 3's run just about $200...The 4's $800 and up. Just for a used one...
