ram van2500 bad missfire
Old May 11, 2011 | 06:09 PM
julianbuckingham@yahoo.co.uk's Avatar
Default miss fire reply
cheers guys i have just been outside with my torch 11pm here !!!and yes there is another sensor i didnt realise was even there , tommorrow i will take the alternator off etc and check it out , it looks damnb awarward to get to , i havent got the other one i ordered yet as the company has them on stock but ran out , if im quick i could cancel it and order the other one ,,, cheers julian
Old May 12, 2011 | 05:33 PM
quick update , alternator and power steering pump removed got the coolant sensor out did a resitance test cold all within in spec , however put it in a pan of boiling water resistance went down to 5.2ohms x1000 . there fore i guess its below working tolerance new one ordered could this be the cause of my missfire , let you know when new one fitted , regards julian
Old May 13, 2011 | 10:56 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by julianbuckingham@yahoo.co.uk
however put it in a pan of boiling water resistance went down to 5.2ohms x1000.
In boiling water the reading should be around 1.0 x1000 or 1K ohms. Your reading is 4.2K higher than that. So as long as you feel you did the test correctly, then the CTS is definitely not going to as low of a resistance as it should.
Old May 13, 2011 | 05:43 PM
iodj44's Avatar
iodj44
Engine miss is common problem BEFORE doing anything you should always perform this bulletin.
http://autorepair.about.com/cs/faqs/l/bl654h.htm
Old May 14, 2011 | 04:48 PM
Default missfire continues
hi guys another day of trying to fix van , no joy , today i fitted coolant sensor and made sure plug leads where placed in accordance with the bulletin , that was in last post , , new leads ordered for next week , and plugs , getting stuck for ideas now ???
Old May 17, 2011 | 04:53 PM
Default more miss fire update
hi all , spent another day on van today , had a result with phoning local usa parts supplier told him my troubles he said bring van over and try some new parts from his stock , and see if anything cured it , i fitted a new throttle position sensor , exactly the same , new ignition coil, no better , bought another set of new plugs , ,, he hooked up his fault code scanner , no faults/ codes found on scanner ,, he looked for air leaks on vacumn side , plus checked what i had looked at done over last few weeks , he removed crank position sensor and found metal shaving on it , but no different , he suggested , a magic eye in distributor , or a 02 sensor in exhaust , any body have any ideas to these ? now on the way home 25 miles ive noticed that missfire is not hardly there if i press the overdrive button on and light is on , can any one give me details of what this button does ie any thing to ign or fuel? thanks for help im running out of ideas now cheers all julian
Old May 19, 2011 | 05:48 PM
Default miss fire gone
hi chaps last post for me , misssfire has gone , i bought new intake charge sensor , and new plugs and leads , as a last attempt to make sure id covered the possibility that id missed something , ive done 50 miles today , varied driving town , country etc and im pleased , it runs the best it ever has , smooth , tickover nice no juddering thanks all for the help and advice , its well apperciated it cost me £125 english pounds in the end , no labour charge at local garage so happy cheers julian
