ram 2500 will not start
Old May 9, 2011 | 12:50 PM
cfeldscher's Avatar
cfeldscher
Default ram 2500 will not start
i have a 2000 ram 2500 van that will not run it trys to start but will not run , smells like it is get to much gas. can anyone help me.
Old May 9, 2011 | 04:46 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Pull of the center wire from the distributor and use it to check for spark while cranking the engine. Do you get spark?
Old May 10, 2011 | 01:03 PM
cfeldscher's Avatar
cfeldscher
no i am not getting spark
Old May 10, 2011 | 03:28 PM
alloro's Avatar
alloro
Do you have a digital voltmeter (DVM)? Because your next step is to remove the 2-wire connector going to the ignition coil and check for 12 volts when the key is on.
