Missfire on 4 Help
Old May 22, 2011 | 07:39 PM
trvcampbe's Avatar
trvcampbe
Default Missfire on 4 Help
Hello everybody,glad to be here. I need a little help..Working on a 1998 Ram Van 1500 3.9 liter 142,000 miles..I got a missfire code for number 4 p0304..
Things i know
125psi compression , 17 inches mercury , 48 to 52 psi fuel pressure--needle on fuel gauge shakes violently from 48 to 52 , engine is running rough and down on number 4..Injector pulse is normal (checked with noid and compared to others)..Plenty of spark to plug..
Things replaced
Plugs , wires , cap , rotor , cam sensor/pickup , crank sensor..Still missfiring..
So i swapped the injector with another and still a dead number 4..No engine noise (valves,bearings , ect)..Swapped the new plugs and still same..Replaced the new plug wire with a known good one and still the same..
Every time i removed the spark plug it is wet with fuel..Any help would be much appreciated..Thanks everybody..
Old May 22, 2011 | 07:50 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Have you connected a test light across the injector wires yet to see if it's pulsing on and off? There could be a short that is causing the injector to stay open.
Old May 22, 2011 | 08:29 PM
trvcampbe's Avatar
trvcampbe
No i havnt..I used the noid light and also switched injectors..Then i used a stethescope to listen to the injectors and it is clicking fine..
Old May 22, 2011 | 09:06 PM
trvcampbe's Avatar
trvcampbe
I will check the pulse with a test light tomorrow..Anybody else?
Old May 23, 2011 | 09:25 AM
trvcampbe's Avatar
trvcampbe
Anybody had a tone wheel go bad?..
Old May 23, 2011 | 01:30 PM
alloro's Avatar
alloro
Tone wheel?
Old May 23, 2011 | 01:54 PM
landyacht318's Avatar
landyacht318
Anybody got a link to the TSB for spark plug wire routing to avoid misfire?
Old May 23, 2011 | 02:21 PM
trvcampbe's Avatar
trvcampbe
Originally Posted by alloro
Tone wheel?
Crank Sensor Reluctor Ring
Old May 23, 2011 | 02:29 PM
trvcampbe's Avatar
trvcampbe
I found it,i will check it out..Thanks..
TSB 18-48-98
Old May 23, 2011 | 04:13 PM
alloro's Avatar
alloro
Flywheel...on these engines the flywheel has 6 or 8 notches which trigger the crank sensor, one for each cylinder.
