94 b350 a/c problem
Old Jul 24, 2011 | 10:17 PM
jlorenzo's Avatar
jlorenzo
Default 94 b350 a/c problem
My van has a separate a/c unit in the rear. (its a 15 passenger) It does not blow cold but the front blows icy. I have noticed something leaking under the right side door. Could it be just condensation from the system? I just did a 6,000 mile drive last month and am getting ready to do 9,500 in august through the south so I definitely want to square this away before i go.
Old Jul 24, 2011 | 10:39 PM
guyonearth's Avatar
guyonearth
If the front is working fine I would suspect that the expansion valve is plugged on the back unit. Each unit normally has it's own expansion valve.
Old Jul 25, 2011 | 12:59 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Since you're getting condensation at the rear unit I'd say the evaporator is good and so is the freon charge. I suspect your blend door is not working properly and is not flipping all the way over to the cold side.
Old Jul 30, 2011 | 04:27 PM
jlorenzo's Avatar
jlorenzo
anybody know of a diagram i can reference?
Old Jul 31, 2011 | 07:40 PM
Chazwel's Avatar
Chazwel
I have the same problem with my 1999, 1500, 5.9, miller merry conversion.
Where is the expansion valve located and where is the vent door located?
I am not sure which panel it may be behind. TIA
