Low Side AC Service Port on 2000 Dodge Ram 3500 Van
I need to find the low side ac service port for my 2000 dodge 3500 ram van so that I can add refrigerant. Determining the proper port has proved very confusing based on where you read in the internet!
I bought a Quest "re-chill kit" that has the gauge and hose. It would appear that the gauge fits/screws on directly to the can of refrigerant, while the hose leading from the gauge/screw fitting is what must be attached to the low side service port (the fitting here is not threaded). However, this is the*larger* of the two fitting on the gauge/hose. This would only fit on the larger of the two ports I seem to be able to find, but most people seem to suggest that the larger port is the high side port and not the low side port.
I have taken a photo that shows both ports. I can't seem to get it to post here, but here is the link:
https://picasaweb.google.com/lh/phot...eat=directlink
You can see the two ports/plastic caps there. The one on the right is the larger port, the one on the left is the smaller port.
I think my van is set up a little differently than what I've been able to find so far. Anyway, if someone can help me with this, that would be great! Don't really wanna blow up a can of refrigerant, or myself.
But there is clear difference between what the front a/c is blowing (cool) and what the rear a/c is blowing (cold), at idle. Any ideas on what the problem could be up front? There aren't two different systems in there, are there???
