DOT 4 Brake fluid?
Old Oct 11, 2011 | 07:31 PM
Tom R's Avatar
Tom R
Default DOT 4 Brake fluid?
i will be using my 3500 van for towing my race car. I am expecting a towing weight of around 8000 pounds(trailer + race car + and stuff inside the van).
considering the weight i will be upgrading the van's pads to heavy duty HAWK pads. Can I also use DOT 4 fluid? Any known compatibility issues between caliper / ABS pump seals and DOT 4 fluid? is this an overkill?
I'm worried about traveling down hills since the van can't engine brake.
thanks for help.
Old Oct 11, 2011 | 10:30 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
DOT 4 is compatible with both the brake system and any residual fluid left behind. Now DOT 5 is something I would think you'd have a problem with if you used it.
