1988 Ram Van B250 5.2l FI Power Windows not working
I just replaced the drivers side power window motor and everything was working fine.
After I started the engine now neither the driver or passenger side power windows work.
The power locks do work.
I checked the fuse box located in the glove box and noticed that #1 has no continuity even after replacing the fuse.
I also checked the fuses under the steering wheel and all check out ok.
I read in the manual that there is a circuit breaker which is suppose to be on the steering column support, but I can't seem to find it. If anyone has a picture of what I am looking for, that would be helpful. Or if someone has any other idea what could be wrong, and why fuse #1 has no continuity?
Thanks in advance.
Thanks in advance.
