Exhaust Fumes in Vehicle
Old Oct 29, 2011 | 07:40 PM
jpian0923's Avatar
jpian0923
Default Exhaust Fumes in Vehicle
1988 Dodge Ram conversion van B250.
Some time back I had a rough running issue and low power. My mechanic did a major tune up and emptied the catalytic converter of rust. Exhaust back pressure caused the low power. The rough running was cured by replacing a failed mini fuel injector.
But now, the smell of exhaust in the vehicle is heavy. How do I resolve this issue? Is it just a matter of keeping the rear door windows closed? Or, is a major exhaust system overhaul in my future?
Old Oct 29, 2011 | 07:44 PM
landyacht318's Avatar
landyacht318
Open windows in the rear, or bad rear door seals will let in exhaust at a prodigious rate. Especially with the front windows open.
Old Oct 30, 2011 | 12:05 PM
jpian0923's Avatar
jpian0923
I was afraid of that.
Old Nov 1, 2011 | 09:30 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Rust along the rear frame rails will also let exhaust fumes into the interior through the floor.
Old Nov 13, 2011 | 02:25 AM
jpian0923's Avatar
jpian0923
I know my catalytic converter is shot. I have not taken a close look at the whole system but am considering replacing at least the catalytic converter myself.
Any helpful tips? Is there any welding involved?
If I feel like changing out the whole system, can it be done without welding?
Old Nov 25, 2011 | 11:08 PM
jpian0923's Avatar
jpian0923
I still need help on this. Anyone?
Old Nov 26, 2011 | 04:03 AM
wantboost's Avatar
wantboost
its going to take welding. MIG at the very least.
I had the exhaust smell when I had the rear windows open (and the fronts) as previously stated.
Now I run open header side pipe, no cat, no nothing... sounds beastly, no exhaust fumes ever, and I get better gas mileage in 3rd direct than I did in overdrive
Old Nov 30, 2011 | 10:53 PM
Rusty93RamVan
While MIG or Stick welding might be the preferred method of assembling an exhaust system it certainly is not the only way. You can buy an entire slip-fit-together exhaust system at your local auto parts store, including a new slip-fit catalytic converter.
Once the pieces of exhaust pipe are inserted together and all of the hangers are in place you then install U-clamps to tighten everything. JC Whitney has been selling these type of exhaust systems for years for just about every car, truck and van ever made.
Not a bad option if you want to do everything yourself in the driveway or garage without using a welder (or if you don't know how to weld.)
