2000 Dodge Ram 3500 No Blower
Old Feb 7, 2012 | 05:39 PM
Tireman!'s Avatar
Tireman!
Default 2000 Dodge Ram 3500 No Blower
There in no power to either leg of the pigtail at the blower motor. If we put power & ground to the terminals on the motor then the motor works. Anyone have an idea?
Thanks
Old Feb 7, 2012 | 08:34 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Check the speed resistor for breakage and power. It's on top of the blower housing under the hood and has a 4-wire flat connector going to it.
Old Feb 8, 2012 | 08:14 AM
Tireman!'s Avatar
Tireman!
There is no power going to the resistor.
Old Feb 9, 2012 | 05:04 PM
alloro's Avatar
alloro
The power comes from the ignition switch, then through a 30-amp fuse, then to the dash selector switch, then to the speed resistor. So your problem is the ignition switch, the fuse, the selector switch, or the wiring somewhere in between.
By selector switch I mean the heat, A/C, vent, defrost, etc. one, not the fan speed switch.
Old Feb 10, 2012 | 01:33 PM
Tireman!'s Avatar
Tireman!
The problem was the low speed blower relay. (not where AllData said it was located). Also when finished blower only worked on high, changed the speed resistor and everything is fine.
Old Dec 22, 2012 | 06:58 PM
Nickkaltsas's Avatar
Nickkaltsas
Default blower motor switch help
Hello like you i have tried everything to no avail have not been able to fix my blower motor i have searched and searched but have not found anywhere low speed blower relay would be located in my truck its an 02 quadcab where did you find yours could you please help .. thank you so much
