What now?
Old Mar 13, 2012 | 01:12 PM
BilltheDrummer94's Avatar
BilltheDrummer94
Default What now?
I've got a 00' Ram Wagon 3500 96k on it. I got a CEL and the code was P0305 Cylinder #5 Misfire. I put in new NGK plugs and new wires, dist. cap, rotor and filter (for the hell of it). It stayed off... For a day or two. Now it's back with the same code. I'm wondering what the next step I should take is.
Thanks,
Bill
Old Mar 13, 2012 | 09:01 PM
stev's Avatar
stev
A problem came up like this a few months ago. Do a forum search under Ram Van and read how it was fixed. I forget the title, but it did deal with engine misfires.
Old Mar 13, 2012 | 09:38 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Is the fuel injector a 12-year old original one?
Old Mar 14, 2012 | 07:48 AM
BilltheDrummer94
I don't know for sure. My guess would be yes though...
Old Mar 14, 2012 | 04:16 PM
alloro's Avatar
alloro
Then you might want to consider that the injector is worn out.
Old Mar 20, 2012 | 05:53 PM
BilltheDrummer94
New bit of information I guess. The light has been off for a few days but still running rough. Today I was stopped in drive for a minute or two after backing up, (was waiting to follow a friend) and the CEL came on again. It stayed on everytime I started after parking somewhere. Just a little while ago, I was parked at a slight side incline. I started it and the light was off... Does this narrow it down anymore as to what it's likely to be? I just want the light to either stay on or stay off. Someone help please!
Thanks,
Bill
Old Mar 20, 2012 | 08:41 PM
alloro's Avatar
alloro
It would be great if you could pull the codes when the CEL turned on after sitting still in drive for those few minutes.
Old Mar 20, 2012 | 09:08 PM
BilltheDrummer94
I don't personally own a code computer. The few times I've checked it I've used a friends. I'm thinking it's still the Cylinder 5 misfire. I could be wrong but it seems to be idleing rough and P0305 (C5 Misfire) is the same code I got before and after changing plugs, wires, cap and rotor.
Old Mar 20, 2012 | 10:50 PM
alloro's Avatar
alloro
If you think a $40 code reader is expensive, try replacing a good $70 fuel injector.
