help for 1 ton front brake job
Old Apr 6, 2012 | 07:59 PM
jeremy.w.bert's Avatar
jeremy.w.bert
Default help for 1 ton front brake job
This is my second time to visit the Dodge Forum ... I forgot my username etc so signed up again. Last time there were 4 or 5 of you top Dodge wrenches that walked me thru a water pump and timing chain replacement on our 97 Dodge Ram Van one ton/360. I had sprung a gasket leak on the timing chain cover, and it was suggested that I go ahead and change out the timing chain and water pump as long as I was in there changing the gasket.. I did this and with your expert advice the repair went very smooth. Thanks .If you don't remember me this may help. I am an experienced Model A wrench but don't have a lot of time on modern vehicles. Now that I am retired from 32 years going to sea as a Merchant Marine i have the time to do it myself but not the money to let someone else. 2 days ago I let Les Schwab take a look at the brakes after my wife heard some suspicious noise, She is the main driver of the van. The rears were fine but the fronts were metal to metal . We had bought the van from the local college 2 years ago and the service records indicated that a brake job was done the previous year . So I didn't take a look and now I will pay for it. Anyway Schwab wanted a whopping 905 bucks for the job wiith only 133 for labor. So i went to the Oreilly Auto parts store next door and priced the parts . Rotor with the sleeve bearing already installed were 50$ where Schwab is charging 178 for the rotor plus another 31$ for the same sleeve bearing . So needless to say I am doing it myself . Now I know how Schwab makes their $ , Parts markup to the max, while only showing a low labor cost . Sure Ill let them do it for 133 bucks but only if I supply the parts! Here is the write up prices....
Labor 133.25
3/4 - 1 ton 8 lug 2wd front disc w/serv bearing brake job parts 204.00
Brake rotors 177.41 each or 354.82 total
bearing cone 23.75 each or 47.50 total
bearing set 31 43 each or 62.86 total
CR seal 15:14 each 30.28 total
Total est. 905.16
So here are my questions . Are all these parts needed? What do I need? Where is the best price online or otherwise to get them? I have the Haynes manual but there is no good exploded view which are extremely helpful to a novice like me . Any advice or help will be much apprieciated Thanks ! Jeremy
Old Apr 6, 2012 | 09:03 PM
Bandit2's Avatar
Bandit2
Hi Jeremy
If I am not buying the parts from My local Car Quest , I use Rock Auto .
For an example , there Economy grade Raybestos rotor is around $ 45 , while the Professional Grade ( what I use ) is around $ 75. but You have to Know What Front end You have .
I have pretty much the same van , but a 2000 .
Bob
http://www.rockauto.com/
Ps
Don't forget Pads , I use Raybestos Professional Ceramic @ $ 50.
And Calipers .
Old Apr 7, 2012 | 10:49 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by jeremy.w.bert
This is my second time to visit the Forum ... I forgot my username etc so signed up again. Last time there were 4 or 5 of you top Dodge wrenches that walked me thru a water pump and timing chain replacement on our 97 Dodge Van one ton/360. I had sprung a gasket leak on the timing chain cover, and it was suggested that I go ahead and change out the timing chain and water pump as long as I was in there changing the gasket.. I did this and with your expert advice the repair went very smooth. Thanks .If you don't remember me this may help.
Your username was: "1 ton dodge 360"
The water pump thread you speak of is: https://dodgeforum.com/forum/dodge-r...over-leak.html
Old Apr 7, 2012 | 02:59 PM
blackvan's Avatar
blackvan
I recommend Rock Auto and Autozone. You can usually find the factory service manual sets on Ebay for $50 - $70.
Old Apr 8, 2012 | 12:10 PM
jeremy.w.bert
thanks for the come. backs. I will check out rock auto auto zone.
