replace pulley's with new alternator?
Old Jun 6, 2012 | 11:56 PM
a1mfw's Avatar
a1mfw
Default replace pulley's with new alternator?
Would it be a good idea to replace the belt pulley's when you replace the alternator? would be on an 02 van 5.2.
Old Jun 7, 2012 | 10:18 PM
funair02's Avatar
funair02
do you mean the idler pulley?
Old Jun 7, 2012 | 10:59 PM
a1mfw's Avatar
a1mfw
basically any or all of the pulley's like belt tensioner pulley, idle pulley and such.
Old Jun 8, 2012 | 05:50 PM
funair02's Avatar
funair02
really depends if the bearings are shot. My idler was shot. How did I know that. When the belt was off I just spun the pulley. If it sounds like it has rocks in it, it is bad...
Good luck.
Old Jun 10, 2012 | 09:40 PM
iodj44's Avatar
iodj44
Agree with Funair02 when the belt is off spin the pully by hand should it spin freely and have no play why change it?
Old Jun 15, 2012 | 10:42 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
I have had and seen several that seemed good when changing the belt only to find out the old bearing went very quickly after the new belt is installed. Personally I recommend and do change my idler, tensioner pulleys when I change my belt. A few dollars now saves many headaches later!
Old Jun 16, 2012 | 06:37 AM
iodj44's Avatar
iodj44
By replacing the pulleys with oem pieces can't hurt but not me.
The War Department(wife) drove a 5.9 Dakota 150K I have
two 5.9 Vans which I have put at least 200k+ between the two.
Out of the three motors the only things to fail was a cracked exhuast
manifold and a starter both on the same van.
We pull our sailboat from Massachusetts to Miami once a year and use the same van pull a camper to Quebec City each fall we have never had a breakdown( knock on wood).
You can replace a lot of things but if it ain't broke and looks/sounds normal I don't touch it.
Just my opinion we all are allowed to have one.
Regards
