1998 van trans replacement
Old Jun 7, 2012 | 05:42 AM
jimmy99ways's Avatar
jimmy99ways
New Member
Default 1998 van trans replacement
I put a used Trany in my van, Now it wont start? I changed the plug 4 the od, because the old one had a bad??or lose wire, It was runing, when i park it, Took a trans out of a 99/360. and its the same.. would there be a reson in the trany for it to not start?
Old Jun 7, 2012 | 12:37 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
If by "won't start" you mean the starter won't turn...test the neutral safety switch.
Old Jun 8, 2012 | 04:29 AM
jimmy99ways
New Member
Default van wont start
van turns over, no fire 2 plugs. drove it in shop. R&R,trany. with used one, the other sliped, The thing ran good, its my work truck. thank you..
