Help to empty gas tank, please
Hi,
Yes, I did. Not quite down over the "E". Still sucking fuel, but with more air in it, so I left the rest inside. I added 5 gal of fresh gas, and the gauge hardly moved up. I suppose it's a 30 gal tank... I have to look that up.
Where do you find the tranny model number, to buy the correct filter and gasket?
Dan
Dan
I'd check the injectors and make sure they are seated fully and the connections are tight. You do realize this is an 8 year old thread don't you? I'd start a new one specifically for your issues
