A/C problem
Old Aug 20, 2012 | 02:26 PM
browne92's Avatar
browne92
Originally Posted by funair02
Yep, that's it. So if that shuts off the compressor when the coil freezes, the part it is wired to is probably some sort of low or high pressure limit switch...guessing low.
Good things to know, but doesn't get me any closer to solving my mystery.
Thanks funair
Old Aug 20, 2012 | 02:33 PM
blackvan's Avatar
blackvan
Old Aug 25, 2012 | 11:27 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by browne92
Well, the blend door is ok.
Okay, what about the lines running to and from the evaporator? Are they cold, hot or equal to the 80 degree output temperature?
Old Aug 27, 2012 | 01:58 PM
browne92's Avatar
browne92
Infrared thermometer says 70 degrees low side pipes, 130 high side. I also (maybe foolishly) tried heating the "chinese hat" portion of the expansion valve a bit with a heat gun and no effect.
Old Aug 27, 2012 | 08:12 PM
alloro's Avatar
alloro
That sounds like the condenser readings at the radiator.
