i messed up
Old Aug 7, 2012 | 08:13 PM
pemorgan's Avatar
pemorgan
Default i messed up
i was testing my high and low pressure switches with a meter for continuity and had it.. then i unplugged the thermostat, or what i believe was the t-stat, and had no continuity so i shorted the plug with a piece of wire and now my van will turn over but will not start..i checked every relay and fuse i could find and they are all fine.. any ideas would be greatly appreciated..thanks i have a 1997 Dodge Ram Van 2500
Old Aug 7, 2012 | 08:25 PM
blackvan's Avatar
blackvan
It might be helpful to know what exactly connector you shorted or what it was actually attached to. Its possible that by shorting this you may have burned out the computer.
The first thing to try is resetting the computer. Remove a battery cable, give it 5 or 10 minutes to be certain and then re-attach and see if it will start.
Old Aug 8, 2012 | 09:18 AM
pemorgan's Avatar
pemorgan
thanks, i'll try that and see what happens.. i've been having trouble finding info on where there might be another fuse box but i'll keep searching..i will get back to you with my progress.. thanks for the help and have a good day
Old Aug 8, 2012 | 09:46 AM
pemorgan's Avatar
pemorgan
just for general info it didn't start after resetting the computer
Old Aug 8, 2012 | 10:16 AM
pemorgan's Avatar
pemorgan
Default thank goodness
well, i found the problem...it was a burnt 10 amp fuse, replaced it and all working normally so thank you for the help black van and thank you Dodge Forum, I'm glad i found your site and i am sure i will be visiting you again soon..
Old Aug 8, 2012 | 11:11 AM
blackvan's Avatar
blackvan
Great, I'm glad you got it working and happy it wasn't anything expensive.
