How many of you have replaced your timing chain
Old Aug 21, 2012 | 10:11 AM
funair02's Avatar
funair02
Default How many of you have replaced your timing chain
Hi all...
I am starting to think that the 'lifter' noise I am hearing (and the noise the tech cant figure out) is the timing chain...
Anyone have experience with this issue???
Thnaks~
Old Aug 21, 2012 | 03:39 PM
sparkzz's Avatar
sparkzz
Nope - no problem with timing chain noise, but if you'll go to Harbor Freight, or an auto parts store, and pick up one of those auto stethoscopes (7-8 bucks), you will be more able to find out where the noise is coming from.
Old Aug 21, 2012 | 04:11 PM
blackvan's Avatar
blackvan
The timing chain symptoms for a Magnum engine are a rattling noise coming from the timing chain case. As sparkzz suggested a stethoscope or a long screwdriver can be used to help track down the location.
Old Aug 21, 2012 | 07:45 PM
Rusty93RamVan's Avatar
Rusty93RamVan
When the timing chain gets loose enough to make noise it is almost always causes a poor idle condition. Check to see if the engine seems to be running unevenly at idle.
Noise that seems to be coming from the timing chain can also be a malfunctioning serpentine belt tensioner.
Old Aug 21, 2012 | 08:20 PM
funair02's Avatar
funair02
Yea - after all I have done, this van should run smooth. It has a wierd vibration at idle. Also it is really hard to pinpoint where the noise if coming from. It sounds like it is everywhere. I have had the heads checked and they are OK. I am going to change the lifter and rockers just for the hell of it, but I am really leaning towords the timing chain. I hear it loud on the front cover, but also in the rear. The lifters sound like they are ticking, but not real loud.
I think I am just going to replace it all...
I did find this -
http://fme-cat.com/LiveDocs/1014.pdf
It isnt for my year but it does say what I am heaaring...
