mil light malfunction
Old Sep 3, 2012 | 12:05 PM
john saterfield's Avatar
john saterfield
Default mil light malfunction
i have an 96 2500 van with a 318. now what happens is i go to start the van and i have to cycle the key 2 - 10 times til the mil light flickers on and off then it stays on and then it stays illuminated then i shut key off and then it will crank. this happened before i changed the ignition switch so i changed it. but it still doing the same thing. after the MIL LIGHT flickers and stays on i shut it off and it will crank and run. but if i shut it off for a minute or so i have to go though this same process to get it to run. if i just turn key on MIL LIGHT comes on and goes right out (less than a second), but cycling key til MIL LIGHT stay on for 2-4 seconds i can shut key off then start the van with no problems. please help
Old Sep 3, 2012 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the Ram Van section. We have some very knowledgeable members that maybe able to help.
Old Sep 4, 2012 | 11:21 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Did you change the key switch or the actual ignition block that the key operates? Sounds like a connection issue with it.
Old Sep 5, 2012 | 07:07 AM
gazza101's Avatar
gazza101
Do you get a code? sounds like when you turn the van on it does a self check, and something is not right, by cycling the van on and off you must be clearing this code to start the Van.
Old Sep 5, 2012 | 11:03 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Next time before attempting to start it, warm up the PCM with a hairdryer for a few minutes. After it's been warmed up try and start the engine. If the MIL problem doesn't show up then you need to replace the PCM.
