Has anyone tried the 2 degrees of advance?
Old Sep 24, 2012 | 09:38 PM
funair02's Avatar
funair02
Default Has anyone tried the 2 degrees of advance?
Hi all.
Since the engine has finally settled down (thanks to all for your help, advice and ears ) I am going to do the timing chain soon.
I got a Cloyes and it says I can advance the timing 2 degrees. Since this van really doesn't ever see above 3-3.5k RPMS, even at 75MPH, I am thinking of doing it.
I am looking for any advice or opinions please. I would like to pull a small trailer in the future also (1500lbs). I know I only have the 3.9, but after the rollers and new everthing it is running pretty well. I am thinking this update would be worthwhile.
Thanks all.
Old Sep 24, 2012 | 10:46 PM
landyacht318's Avatar
landyacht318
My Cloyes had 3 keyways too. I was worried if I advanced it I might not be able to pass smog so I chose the middle stock keyway. At least on my year I can twist the distributor to compensate somewhat, but I think on yours, spinning the distributor only affects injector timing.
Looking forward to seeing what others have to day about this
Old Sep 24, 2012 | 11:54 PM
stev's Avatar
stev
Ah, that will not work with your van. Your van's timing is regulated by the PCM computer and not the distributor. Thus turning 2 degrees will not help, it may hurt dealing with the O2 sensors.
From 1993 and back, this trick would work.
Old Sep 25, 2012 | 12:06 AM
landyacht318
stev, he is referring to advancing the camshaft itself 2 degrees with the different keyways available on some cloyes timing chain sets
