What is the stereo size in our vans - DIN 1.5??? (2002)
Old Nov 1, 2012 | 09:06 PM
funair02's Avatar
funair02
Default What is the stereo size in our vans - DIN 1.5??? (2002)
I can't see to find a straight answer? Is it DIN 1.5?
Thanks
Old Nov 1, 2012 | 11:18 PM
blackvan's Avatar
blackvan
Old Nov 1, 2012 | 11:29 PM
Rusty93RamVan's Avatar
Rusty93RamVan
If you buy your head unit from Crutchfield they will supply you with the correct adapter for your dashboard + DIN size and also with a direct fit plug for the speaker/power connector on your harness. You just have to connect the loose wires on the end of the harness plug to the correct wires on your head unit. But everything is color coded IIRC and is easy to get wired.
Old Nov 1, 2012 | 11:41 PM
blackvan's Avatar
blackvan
Old Nov 2, 2012 | 09:10 AM
funair02's Avatar
funair02
Im thinking of putting this one in. 90x4! Marine grade...
http://www.ebay.com/itm/Pyle-PLCDMR9...item4169cceb4c
Old Nov 2, 2012 | 09:19 AM
blackvan's Avatar
blackvan
Old Nov 2, 2012 | 10:57 PM
funair02's Avatar
funair02
Originally Posted by blackvan
You can get a lot more bang for your buck today. Checkout the JVC Arsenal models with Bluetooth, 2 USB & 1 aux inputs, remote control, android remote control app and 3 sets of preamp outputs.
you are correct, sir! Thanks for the suggestions
Old Nov 3, 2012 | 05:12 AM
Rusty93RamVan
I bought my JVC head unit from Crutchfield. I didn't like and ultimately did not use their DIN adapter because the plastic was too flimsy for my taste. Their speaker and power wiring adapters were good and include intelligent instructions so I would second this for that reason.
I found their installation kit to be of a high standard all the way around and am quite satisfied with it. To each his own.
