2002 dodge ram van 3500 rear end/differential options? as mine is toast
Old Nov 15, 2012 | 11:11 PM
cbrkp's Avatar
cbrkp
Default 2002 dodge ram van 3500 rear end/differential options? as mine is toast
hey all,
my rear end is toast, gears are severly worn, pinion shaft is shot too .
what options are there for my model? are there interchangable rear ends that I can use from the vehicles?
Old Nov 16, 2012 | 11:08 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Just grab one from a junkyard and swap it out. The junkyard has all of the interchange information.
Old Nov 16, 2012 | 11:52 AM
DoubleWasp's Avatar
DoubleWasp
Just make sure that the JY rear is not in just as bad of shape. There are a lot of bad chrysler rears out there, because people use cheap transmission fluid, and the resulting torque converter shudder smashes the rear to bits. Not literally, but you definitely end up with the same issues.
Old Nov 16, 2012 | 12:43 PM
01tilehauler's Avatar
01tilehauler
I bought a 9.25 posi out of a totaled dakota off e-bay 4-5 years back for $50, replaced all the bearings for my 2001 3500 and I enjoy not getting stuck in wet grass anymore.
Very happy.
The trick is setting it up correctly.
George
Old Nov 19, 2012 | 10:02 AM
ComicDom1's Avatar
ComicDom1
I let my local dealer rebuild mine. After checking the salvage yards and the cost of having someone swap it out or doing the work myself, it was just financially smarter for me. The work also has a years warranty. Since I am getting older I felt I needed to let someone else do the heavy lifting and have the headaches.
Jason
Old Nov 25, 2012 | 08:56 AM
cbrkp's Avatar
cbrkp
thanks for the advice guys, a few options atleast
Cheers!
Old Nov 25, 2012 | 09:25 PM
stev's Avatar
stev
The Chrysler Corporate 9 tends to be the standard 3.92:1 rear for the 8-lug rear for the B2500 and B3500 after 2000. Ideally, the 3.55:1 would be nice for MPG overall, but the axle wheels are 5-lug and 15-inch tires. There are conversions for the gears in the rear to customize.
A 3.23 to 3.25 would be excellent for MPG, however the torque would be dismal to tow anything or haul a heavy load.
