blower fan switch only works on 1 & 4, changed the resistor already
Old Nov 25, 2012 | 09:06 AM
cbrkp's Avatar
cbrkp
Default blower fan switch only works on 1 & 4, changed the resistor already
Hey all,
so my blower fan switch has recently started to fail, on setting 2 & 3 it does not work. 1 & 4 however does work. One cold day the blower fan was running then stopped working altogether, next day it was working. not sure if its the blower, resistor, or switch.
I've:
-tested the blower fan by taking power to it directly and it works.
-changed the resistor
its is possible the panel switch is defective? or things I should look into?
Old Nov 25, 2012 | 12:23 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
This would be my thought as well.
Old Nov 30, 2012 | 12:19 PM
ComicDom1's Avatar
ComicDom1
There is a vacuum hose that goes to valve up front. It is a very small hose so check it for dry rot or breaks. That is what caused mine to behave that way, not the resister.
Jason
Old Nov 30, 2012 | 08:32 PM
alloro's Avatar
alloro
How would a leaking vacuum line effect the electrical operation of the blower motor?
Old Dec 1, 2012 | 10:55 AM
ComicDom1's Avatar
ComicDom1
The real answer is I was in a hurry and reading and posting on a portable device and I misread lol. Therefore my answer was wrong. I did have a situation where I my blower was putting air out from windshield vents to the floor and alternating back and forth at random. That was a vacuum hose problem and that is what triggered my answer.
I apologize. Please disregard my first response in this thread.
Jason
